spool vs. mini spool - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2009, 10:04 AM
72fordlb's Avatar
BARN BURNING BIG BLOCK!
HEy so i bought a parts truck for the 72 f100 and it was a drag truck with a 4:10 non posi rear and i want to make it posi so should i go with a spool or mini spool. I do know difference between the two but which will work better or last longer? And if so do they act differently?
Old 11-14-2009, 10:18 AM
speedfreak2's Avatar
WrenchingAce
With the mini spool, the weakest link is the pin that locks the spool to the carrier. WHEN that breaks, you're done. I would opt for a full spool over a mini spool any day.
Old 11-14-2009, 10:20 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
If it's a drag truck only that will see no street use, I would go full spool instead of a mini. The full spools are stronger and will last longer. Make sure you get one for drag racing and not dirt racing, there is a difference.
Old 11-14-2009, 10:28 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Could you en-lighten us as to the difference as my supplier only carries one kind of spool
Sam
Old 11-14-2009, 11:03 AM
S10 Racer's Avatar
Sam
When I was looking at buying a full spool for my S10 drag project, I almost bought one because of price alone but found out it was for dirt racing which according to the company that was selling it, was not a good choice for a drag race application. I ended up buying an Auburn full spool from the same company.
Old 11-14-2009, 12:21 PM
cranky1's Avatar
Just stuck
The only thing I can think of is one is a lightweight vs a standard weight spool. Might not want to use the lightweight one on dirt....?
Old 11-14-2009, 12:32 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
If it's a street ride only. I mean more time on the street then the track i would'nt even consider a spool of any kind. They are designed to go straight the do not do well around turns, They will bind up and can snap a axle and if jar on it in a turn a spool is just like a welded up gears IMO. I have had and still have spools but i won't run them in a street ride. JMO.........(OneMoreTime ..Sam ) I will answer the question for you of you don't mind..............Here is your answer. A mini spool fits inside the standard open differential carrier replacing the spider gear assembly completely, same thing as a mini-locker. But they both do the same thing.
A full spool replaces the ring gear carrier and spider gear assembly completely with a single piece. ................Cole
Old 11-14-2009, 02:44 PM
prostreet6t9's Avatar
Differential/Driveline
They will act exactly the same. Same end product just a different way of getting there. Full spool is much stronger and will last longer.
Which Differential do you have? 9" or Dana 44? If it's a 9" maybe consider a Trac Lok? Yukon has a great unit for the 9". If its a Dana 44 I would try and find a Power Lok unit for it.
mini spool eatonde Transmission - Rearend 2 12-22-2008 11:42 AM
Mini spool question KGRIFF Transmission - Rearend 28 06-12-2008 11:18 PM
Mini Spool install Trouble gm 8.5 jsteve068 Transmission - Rearend 5 05-26-2006 08:28 AM
difference/pros/cons of spool and mini spool? "70" Cougar Transmission - Rearend 20 03-03-2006 10:42 AM
What's a spool and mini spool? 84Z Transmission - Rearend 2 01-31-2005 07:33 PM
