Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Spool whit OEM axles?
Old 02-20-2012, 05:03 PM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
Originally Posted by clance54
I've got a 10 bolt and want to run a spool. Can I do so with the original axles and ce-clip eliminator kit?
Yes you can use Oem axles with c-clip eliminators. If you ever break one you can go to a good aftermarket axle and gain some strength.
