Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Spool whit OEM axles?
Old 02-20-2012, 06:43 PM
sparkchaser sparkchaser is offline
It is very dangerous to run a spool with OEM axles. If one breaks the other axle will spin you around faster than you can react. With a posi or open rear end, if one axle breaks the car stops, with a spool the remaining axle keeps pulling. NHRA does not allow OEM axles on locked rear ends for this reason.
