Spool whit OEM axles?
I've got a 10 bolt and want to run a spool. Can I do so with the original axles and ce-clip eliminator kit?
not on the street
X2. Many years ago I ran a spool on the street. cost me well over $30,000.00 in nineteen eighties dollars!
Thanks for the help guys. It will be on the street for a short while till I switch to a posi.
I got away with it, and I wasn't even using a c-clip eliminator. still, don't do it.
It is very dangerous to run a spool with OEM axles. If one breaks the other axle will spin you around faster than you can react. With a posi or open rear end, if one axle breaks the car stops, with a spool the remaining axle keeps pulling. NHRA does not allow OEM axles on locked rear ends for this reason.
Aftermarket axle rule is at 10.99 and quicker. Many cars at the track with Shortened OEM axles and a spooled rear.
| All times are GMT -6. The time now is 09:37 PM. |
