not on the street
I got away with it, and I wasn't even using a c-clip eliminator. still, don't do it.
It is very dangerous to run a spool with OEM axles. If one breaks the other axle will spin you around faster than you can react. With a posi or open rear end, if one axle breaks the car stops, with a spool the remaining axle keeps pulling. NHRA does not allow OEM axles on locked rear ends for this reason.
| can you remove raised whit letters from tires | cornfieldcars | General Rodding Tech | 12 | 05-19-2011 06:11 PM |
| Full Spool or Mini Spool??? | S10 Racer | Transmission - Rearend | 1 | 04-02-2008 06:50 AM |
| whit bazemore lost his ride..... | crazy larry | Hotrodders' Lounge | 23 | 10-02-2006 02:04 PM |
| difference/pros/cons of spool and mini spool? | "70" Cougar | Transmission - Rearend | 20 | 03-03-2006 10:42 AM |
| What's a spool and mini spool? | 84Z | Transmission - Rearend | 2 | 01-31-2005 07:33 PM |
