spools - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2003, 03:11 PM
camino_man's Avatar
go like he11 machine
Post spools
i was just wondering what yalls thoughts were on running spools in a daily driver and what kind of problems they can cause. thanks
Old 02-06-2003, 03:17 PM
dmorris1200's Avatar
doesn't play well with others
Post
Well if you use the search engine entering spools for search word in trans-rear section you could get a history of all old threads containing info on spools. Here is the most recent thread.
rear end spool
BUILT FORD TOUGH
Old 02-06-2003, 03:19 PM
kiaserknife's Avatar
Post
Its hard on your tires...and rear-end...everybody I know who has done it doesnt recommend it.m2cnts
Old 02-08-2003, 01:50 PM
cuda66's Avatar
Post
I personally have one in my cuda and I love it!!!! I heard all the horror stories and I decided that I would add one in my car due to the cost of a locker assembly!!! The only problem that I have noticed id that when you turn a sharp corner you will hear one of the tires slipping. Now I dont drive my car everyday but I do drive it about 2 to 3 times a week. one thing to think about is tores and axel diameter. If you are running a cheeter slick or something you will bind up the rear and will probably tear you the axels. But as a genral rule there is enouh dirt and debris in most corners that you will get the wheel slippage to keep you from tearing up anything. one thing I would warn you about is always slow way down before you take a real sharp corner. Have fun and make it go fast. one thing I love about it is. It smells better when you can burn one tire down but it smells better when you can do it to two. Cudaman
<img src="graemlins/evil.gif" border="0" alt="[evil]" />
