Sportsman pro tires? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2013, 09:23 AM
I have a 4 speed car that i drive daily in the warmer months and wanted some opinions on these tires. I was leaning toward the Bias Ply ET Street tires, but being a daily driver i figured they wouldn't last very long on the street. Last year i used the ET Street Radials although they didn't work very well with my 4 speed. So anyone using the Sportsman Pro tires have an opinion on them? or any other tire that might work for my setup? Thanks.
Old 03-27-2013, 09:41 AM
33Willys77's Avatar
I have used Hoosier Quick Times. Work ok on the street and pulled front wheels off the ground on the track (ran low 10's).
Old 03-27-2013, 11:08 AM
Willys, were those the ones with the tread on them or just the 2 groves cut into them? Thanks
Old 03-27-2013, 11:24 AM
33Willys77's Avatar
With treads - DOT tires
Old 03-27-2013, 11:29 AM
Thanks i'll check them out.
Old 04-02-2013, 02:02 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I run M/T Sportsman Pro DOT treaded 31 x 18.5's (with tubes) on the street and track, low pressure, anchored rims. Running an Extreme Automatics spragless 400 with a Griner brake it hits very hard and the tires will hold it most of the time.
Semper Fi
Pro-Trac tires Zimmo General Rodding Tech 7 12-29-2009 10:34 AM
Pro Street tires RONNYinWAXHAW Hotrodders' Lounge 0 09-25-2005 12:24 PM
front tires, sportsman 72chevelle Garage - Tools 3 09-30-2004 02:30 PM
Where can I purchase pro street tires ??? STATUTORY GRAPE Transmission - Rearend 1 09-03-2004 07:03 PM
Pro Street Tires Fire4103 Hotrodders' Lounge 1 12-17-2001 04:46 PM
