spot cutter idea
why hasn't anyone made a bit you can put in a drill with a sleeve around it to stop it at a certain depth? Doesn't that make sense. They can have a bit for differing gauges. I dunno, just seems like it would work and be easy to design and not have to cost $300. Thoughts?
I have a set of different diameter drill stops that would do the same thing and would work on my spot weld bits. Don't waste the time installing one.
Trees |
wanna sell it? Didn't think so.
Make the length of the tubing within 1/8" of the exposed drill bit. Loosen the chuck slightly and adjust the stick out of the drill bit through the tubing while maintaining contact between the chuck jaws and the tubing. Once you are satisfied with the stick out when the chuck is re-tightened then remove the tubing. Add a dab of silicone into the tubing and slide back over the bit. Make sure the tubing is tight against the chuck jaws and the bit is still sticking out the proper distance. The silicone will keep the tubing from falling off the bit when in use. |
| Recent Garage - Tools posts with photos |
| 67 GTO, LeMans body. Good Idea? Bad Idea? | GoatGuy | Hotrodding Basics | 54 | 06-08-2011 10:54 AM |
| plasma cutter | Holder350 | Garage - Tools | 13 | 10-30-2007 09:07 AM |
| 1988 chevy s-10 blazer, and i want to put a 327 in it. comments, good idea bad idea. | 1969css | Introduce Yourself | 1 | 12-22-2004 05:18 AM |
| Which spot weld cutter do you recommend? | Dejavu | Body - Exterior | 4 | 12-10-2004 02:18 PM |
| I need plasma cutter help | willys36@aol.com | Garage - Tools | 11 | 06-20-2004 08:03 AM |
