Spot Repair - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2006, 04:58 PM
Spot Repair
I'm working on repairing a 93 Ford Taurus. The car has some small dents and scratches on one of the doors and I am wanting to remove the door....do a little dent repair and then just paint 1/2 of the door where I fix the dents.
Heres my question: I am wondering what the odds are of me being able to spray the repair area (upper 1/2 of door) and have it look comparable to the original factory job on the bottom 1/2 of the door and the rest of the car? I would like to use a single stage urethane the same paint code as the original color.....its a silver metallic.
I havent done "spot repair" painting before so If my odds are low that I would be able to do it successfully....then i will just forget about fixing it since this is just a daily driver car.
Old 09-28-2006, 08:49 PM
willys36@aol.com's Avatar
Wiki Edits: 21
You odds of a successful match are 0.000000%. That is a real art and takes years to perfect. I have tried to do patches using paint form the original paint job and failed. A door isn't so big that you would be WAY ahead repainting the whole thing. Absolutely no advantage to trying to skimp to only part of the door.
Old 09-28-2006, 09:00 PM
THanks for the response......I kinda figured I my odds were nil.
Old 09-28-2006, 11:10 PM
adtkart@aol.com
First, I cannot imagine removing a door to repair some small scratches or dents. Second, as Willis said, not much chance of getting that good of a match, specially with silver.
Aaron
Basecoat spot repair question ? 1958FordF100 Body - Exterior 7 03-07-2006 09:36 AM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
Cheap decent spot repair WakBordr7387 Body - Exterior 4 09-20-2005 08:06 AM
Fresh Base reacting with old base on spot repair myfamiliacc Body - Exterior 11 03-20-2005 08:07 PM
Spot repair question Dbodily Body - Exterior 3 05-12-2004 10:32 AM
