Spot repair question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2004, 04:58 AM
I have a small dent in my front fender. this will be my first time doing a spot repair on a base coat clear coat system. From what I have read in this forum I understand that after I repair the dent and put the base coat down I need to clear the entire panel to avoid any problems with chemical staining etc. My question is do I re-coat the entire panel with the base coat also or just the area that is damaged and repaired? Thanks in advance. David
Old 05-11-2004, 06:20 AM
Wiki Edits: 49
If you're an experienced painter you can spot just the repair and blend in the base on the surrounding area. However for someone who doesn't paint cars every day I would suggest shooting the entire panel with the base as well. Unless your paint job is pretty old and faded you should't be able to notice much of a difference.
That's the way I'd do it anyway.
Centerline
Old 05-11-2004, 02:03 PM
Thanks for the info
Old 05-12-2004, 11:32 AM
sportbikeluvr's Avatar
centerline- are you in agreement that the entire panel shld be cleared regardless if one just bc's the repair area?
