Spray after filler work? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2009, 11:27 PM
I sprayed my SPI epoxy over my stripped and DA'd metal. Now I applied my filler and did my body work. Now I have nice smooth filler and metal spots from where I sanded the epoxy. Do I apply one more coat of epoxy over everything before I apply my 2K primer? Thanks.
Old 07-17-2009, 04:29 AM
Last journal entry: 50 Ply wagon
If you have bare spots, I would put a light coat of the SPI on those spots, then coat the whole vehicle with the 2K
Old 07-17-2009, 07:39 AM
302 Z28's Avatar
Yes reapply the SPI epoxy to those areas. The SPI can be feathers if need be then apply your sanding primer as suggested.
Vince
Eliminate filler pinholes with dental pik and credit card cboy Body - Exterior 8 05-21-2009 05:48 AM
Sprayable Body Filler robs ss Body - Exterior 10 11-19-2007 06:56 PM
Why do I struggle with bodywork so much Arrowhead Body - Exterior 32 08-16-2007 09:12 AM
The most common mistakes made by the newbe working with plastic filler. MARTINSR Body - Exterior 7 02-14-2006 10:21 PM
My first Spread..... Of filler that is.. satexasf150 Body - Exterior 17 01-02-2006 10:24 AM
