There is no such thing as epoxy primer or paint from a spray can, it is physically impossible. Epoxy requires the mixing of two or more chemical compounds to initiate a reaction which cures (hardens) the primer or paint. I do not care what it says on the label, it is not epoxy, that is strictly a marketing ploy. Of the three you mentioned the primer/sealer is the one you want, but it will provide limited protection.
Vince |
Or buy some quality epoxy and brush it on and follow up with a roll on type urethane surfacer if you don't have access to spraying equipment. This method would be crude but will work. Some epoxies are designed for brush applications and many shops across the country are using the roll on type surfacers. Just a thought,
