Spray clearcoat over clearcoat, should I sand first? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2009, 04:53 PM
Hello,
I want to repair a rust spot on my car. It's a really small spot of 1 sq in. DBM suggests me to blend the colors instead on painting the whole panel. I like the idea because it's seems more difficult to do.
Now, my question is about spraying clearcoat over the old clearcoat. I am gonna spray Dupont Nason clearcoat over the original clear. Should I sand the original with a grit of maybe 1000-1200 before applying the new clear? I wonder if the new one will stick properly without sanding.
And I have another general question. If you sand your clearcoat and it becomes dull, can you spray a new layer of clear over it to make it clear again?
Old 10-14-2009, 05:10 PM
You can hit the old clearcoat with a scotch brite and then spray clear over it and it will be fine. When you scotch brite or sand the clear it will get dull but once you throw clear on top it will shine again.
Old 10-14-2009, 05:23 PM
deadbodyman's Avatar
Wiki Edits: 11
Red scuff pads are what the color sticks too and gray are for clear,so before you spray color use a red pad for everything getting color then go to gray for the clear over clear spots.
Old 10-14-2009, 05:29 PM
Is there a product number for these scuff pads? Or if I ask for gray scotch brite the guy at the auto parts shop will give the right thing. From previous experiences, it could be dangerous to look for something when you only know the color of the package...
Does the same rules apply if I want to spray bc/cc over an acrylic enamel paint? Because I want to train on garden tools before attacking my own car and I believe it is painted with acrylic enamel paint.
Old 10-14-2009, 05:36 PM
Wiki Edits: 11
3-M scotch brite...red pads #07747......gray pads #07748......They come in 3-pacs too... not sure if its the same number
Metal Spray information incthermion Introduce Yourself 0 11-17-2008 01:29 AM
Not Another Spray Gun Question! Workingwoods Body - Exterior 11 07-17-2008 02:07 PM
low priced spray gun/detail gun for primer/base/clear and ghost flames jrmy_1 Body - Exterior 15 06-08-2008 06:38 AM
spray can clearcoat entire truck? bigolblackie Body - Exterior 8 10-15-2006 08:55 PM
I'm good with a spray can.... what am i doing wrong! harrington Body - Exterior 21 04-25-2004 01:28 PM
