Spray Gun for Adhesive - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2005, 08:19 PM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
What type/brand of spray gun do you guys recommend for spraying adhesive? I built a fiberglass dash and center console for my S-10 along with new door panels. Everything will be covered in tweed. Ive had success in the past using 3M adhesive from a spray can, but this time Id like to have everything stick for good. Most everything will be covered with closed cell foam then tweed. Also, could you recommend a source and type of adhesive? Should a gallon be enough?
Thanks!!!
Old 07-28-2005, 08:41 PM
302 Z28's Avatar
I would by the cheapest HVLP gun you can find. Follow the manufactures spec sheet for the adhesive for tip size and thinning requirements.
Vince
Old 07-29-2005, 12:28 PM
Interiors by Shannon's Avatar
Hey, I'm just the interior guy
I just use a cheap paint gun and weldwood spray adshive. No thining. It's best to put a way on the gun to turn the air pressure up and down where the air line hooks up.
Old 07-29-2005, 10:00 PM
I have a cheap $10 Harbor Freight Siphon gun I have been using for upolstery adhesive for three years now. If it does plug up, I'll just get another one, it isn't worth the time to clean it.
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
one giant orange peel flamedfordbronco Body - Exterior 14 06-20-2007 09:04 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
harbor freight hvlp gun jn0w Introduce Yourself 2 06-15-2004 03:08 PM
