Spray Gun question, FLIII - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2005, 04:09 PM
Bluepen's Avatar
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
I have a question about the Finish-line 3 spray gun. One is in shipment to me at this time and a local painter/hobbyist told me the FL-3's have a bad habit of clogging with both primer and finish paint(with the proper tips). He told me when I start using it to use about 10% more reducer and add coats to prevent it from clogging up. Anyone else have this problem or heard of it??
Thanks
David
Old 05-31-2005, 06:57 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Nope. Been using one for 3 years now and NEVER had anything like that UNLESS,
I either didn't CLEAN it GOOD after use or was using the WRONG reducer.
Does you buddy use paint STRAINERS??
Even with PRIMER??
THAT is the #1 reason gun's jamb up.
People don't strain the paint or primer. Yes,Primer as some of the high solids stuff will clump and that will stop a gun cold in it's tracks.
Is he using the right tip size for the product being sprayed?
1.3-1.4 for most base's & clear, 1.8-2.0 for primer.
The last problem is with the filter in between the cup and fluid area.
I pull it out for primer or paint but use it religiously for clear coat.
Devilbiss FinishLine Spray gun opinions wanted rodnok1 Body - Exterior 5 11-17-2006 06:07 AM
Best Way To Clean A Clogged Spray Gun? way_2fast_4u Body - Exterior 14 05-11-2005 02:46 PM
Electric spray gun cutsupreme Body - Exterior 11 03-24-2005 12:08 PM
Harbor Freight Spray Gun Gro Harlem Body - Exterior 21 03-19-2005 09:54 AM
Spray Gun Tip Size to prevent orange peel Gro Harlem Body - Exterior 5 03-14-2005 02:57 PM
