Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 03-13-2005, 05:55 PM
Gro Harlem's Avatar
Gro Harlem Gro Harlem is offline
New Member
Spray Gun Tip Size to prevent orange peel
I've been having problems with my gun. I can spray the basecoat just fine, it goes on smooth but when I spray the clear coat it orange peels like crazy!! I adjust the nozzle between stages so I am thinking maybe the nozzle is too big.
Its a 1.5mm nozzle. I'm using a urethane-based Western "Dimension" clear "overall clear" that uses a 4-1 ratio of hardener, no reducer.
Would it be possible to add reducer to the clear to thin it up some? The spec sheet on the clear doesn't say anything about it so I'm not sure if it would cause a reaction or not.
And is a particular size tip nominal for urethane-based 2 stage paints like the kind i'm using? I can get a 1.3 or 1.4 if needed.
Old 03-13-2005, 06:13 PM
baddbob's Avatar
baddbob baddbob is offline
re: Spray Gun Tip Size to prevent orange peel
What is the make and model of your gun? What air pressure are you spraying at? Bob
Old 03-13-2005, 07:07 PM
Gro Harlem's Avatar
New Member
ignersoll-rand 270g 40psi
Old 03-13-2005, 09:40 PM
eclipse3315 eclipse3315 is offline
you'll get the best results with a 1.2 or a 1.3mm tip, it atomizes the clear better... shoot with 100 psi on the wall, and like 25-30 psi at the regulator on the gun... also depends on your technique too, if you go too fast then the clear will orange peel, but if you go too slow then it will run, there's a fine line... it takes some getting used to...
Old 03-14-2005, 04:42 AM
jcclark jcclark is offline
The Penny Pincher
I've never been able to spray clear smooth enough without adding reducer.
I know a lot of people do but I haven't been able to.
Different clears are different viscosities, I've had some like water and others
are so thick there's no way you wouldn't thin a little.
I've tried all different tip sizes and have gone back to what works for me,
adding reducer and using a little slower reducer than what's recommended.
Just be sure to allow longer time between coats for flashing when doing this.
I have one reducer that's so slow it takes 45 min to flash, but it lays
the clear on like oil, I use it for bumpers that I don't want to buff out.
I've talked to ten different painters and got ten different answers.
There's good advice on this forum but everyone "tweaks" their settings a little.
You have to find what works best for you.
Old 03-14-2005, 01:57 PM
p8nter's Avatar
p8nter p8nter is offline
Sounds like your not putting it on wet enough or using to fast of a hardener for your shop temperature. A smaller head will atomize better but you can usually compensate with higher air pressure.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Spray Gun Tip Size to prevent orange peel"
More on Orange Peel KarKen Body - Exterior 32 02-27-2006 06:50 AM
"Basic of Basics" How do I paint my car myself? Centerline Body - Exterior 1 11-26-2005 08:12 PM
Martin Senour Tech Sheets? unstable Body - Exterior 40 04-23-2005 11:34 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 07:49 PM
harbor freight hvlp gun jn0w Introduce Yourself 2 06-15-2004 02:08 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
