Spray Gun Tips - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2005, 08:20 AM
New Member
Spray Gun Tips
What is the best size tip to use for 2k urethane primer and then Acrylic Urethane non metallic dark Blue Color
Old 06-16-2005, 09:16 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Not to be a wise guy, but your tech sheet will tell you that information. The paint manufacturer will tell you all the required set up instructions. They are as important or MORE than the tip size.
Air pressure
which Thinners/reducers/activators are required
Mixing rates
COMPATABLE surfaces
temperature to spray, and what products to change for differing temps
and a whole lot more!
Definately worth reading.
"Basic of Basics" How do I paint my car myself? Centerline Body - Exterior 5 11-07-2011 07:14 AM
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
harbor freight hvlp gun jn0w Introduce Yourself 2 06-15-2004 03:08 PM
