Is this a brand new spray gun you are using? Sounds like a couple different problems from all the shapes you described. If the pattern isn't parallel and even and curved in the middle, one of the holes on you aircap could be clogged or possibly something bent. The other patterns you described I don't know, but sounds like too much pressure, and fan pattern turned out too wide. Hopefully someone else will give their ideas also.
