Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - spray gun tuning help please..
Old 06-29-2005, 10:27 PM
the milkman the milkman is offline
I have used auto air in my airbrush for a few months, and have had a lot of problems with it being too thick. Your paint my be drying up at the needle tip, and causing it to spit, and could be partly to blame for you pattern. Try thinning you base out about 10-15%, and dusting your coats on really thin. Auto air says you should use there thinner for the binders in it, but I have used only water, and have not had any problems with adhesion. Good luck
