Is this a brand new spray gun you are using? Sounds like a couple different problems from all the shapes you described. If the pattern isn't parallel and even and curved in the middle, one of the holes on you aircap could be clogged or possibly something bent. The other patterns you described I don't know, but sounds like too much pressure, and fan pattern turned out too wide. Hopefully someone else will give their ideas also.
its a brand new gun.
after posting, i figured i oughta take a closer look at my equipment and i went a took the tip off and brushed everything out really good. i'm gonna go back out and shoot some more later.... any input is greatly appreaciated. thanks Last edited by alteredpilot; 06-26-2005 at 06:05 PM. |
The banana or curved pattern is a blockage in the airhorn holes. Most touchup guns don't have cap holes other than the main fluid opening.
Could be trash/defect from the drilling during manuf. or from the air supply. Possiable air leakage around aircap seal where it screws on to the gun.Not the paint nozzel,the "ring" you tighten around the airhorn.Some have an O ring or Teflon washer to seal this. The Q-tip or dumbell is air/fluid misadjustment,Most likely,too much air pressure as your blasting 55 into the gun. Most HVLP want around 20-30. Never shot this water base myself but it sounds like it's too thick to atomize properly which is why your cranking it up to 55 and your spray pattern is going to heck.. Last edited by Bee4Me; 06-27-2005 at 01:09 PM. |
in talking with a few painters, i'm thinking i had too much fluid flow. i'm learning that it doesnt take much of an adjustment to make a dramatic difference...
back at it tomorrow.. |
I have the same gun and I had no problem shooting Acrylic Enamel with it at the recomended 21PSI at the gun. These guns are budget, but the craftsmanship on mine seems to be very good. I think your problem is in the paint mixture, air pressure, and gun adjustment. It does not take much paint to shoot test patterns, so I would suggest mixing some paint up and just keep adjusting until you get a good pattern. You'll get it, just keep trying.
I have used auto air in my airbrush for a few months, and have had a lot of problems with it being too thick. Your paint my be drying up at the needle tip, and causing it to spit, and could be partly to blame for you pattern. Try thinning you base out about 10-15%, and dusting your coats on really thin. Auto air says you should use there thinner for the binders in it, but I have used only water, and have not had any problems with adhesion. Good luck
| Martin Senour Tech Sheets? | unstable | Body - Exterior | 42 | 03-12-2011 09:09 PM |
| More on Orange Peel | KarKen | Body - Exterior | 36 | 03-22-2009 02:18 PM |
| one giant orange peel | flamedfordbronco | Body - Exterior | 14 | 06-20-2007 09:04 PM |
| Orange peel in the clear | Montypierce | Body - Exterior | 13 | 03-06-2005 08:49 PM |
| harbor freight hvlp gun | jn0w | Introduce Yourself | 2 | 06-15-2004 03:08 PM |
