Spray Painted Interior Panels - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2012, 12:58 PM
Mac88's Avatar
"Drive It Until It Breaks"
I just spent about 45 minutes trying to remove black spray paint from my back interior panels, which were originally grey. After scrubbing, it looks like panels had been sprayed with a primer too. I tried sandpaper, which is slowly removing it, and I even tried oven cleaner. I read in another forum that it worked pretty well on plastics. Has anyone ever tried paint thinner or remover on their panels? I know those chemicals are strong and could damage the plastics, but has anyone tried it? At the rate I'm going, it will take me forever to get these panels free of the black paint.
Old 06-27-2012, 02:44 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
I'm going to ask the obvious question (to me, at least)-is this "spray paint" Catalyzed or Spray bomb?
Old 06-27-2012, 03:05 PM
Mac88's Avatar
I have no idea. Im assuming just regular spray paint.
Old 06-27-2012, 03:06 PM
Mac88's Avatar
I have no idea. I am assuming just regular spray paint.
Old 06-27-2012, 03:56 PM
35WINDOW's Avatar
If it's a spray "bomb", Laquer Thinner will take it off, but you gotta be quick about it or it may soften the good Paint underneath-if it's catalyzed, I'm afraid your sandpaper route may be your best bet-
Hopefully you'll have enough material left to buff it out afterwards-
Old 06-27-2012, 06:35 PM
Last journal entry: Latest picture
Are your original panel molded in the proper colour, or were they too painted?
If they are molded in colour, then use caustic soda, lye, drain cleaner or oven cleaner. They are all basically the same (caustic) and they will melt the paint without damaging the plastic, even if your panels are made from ABS.
Do not use lacquer thinner, because it will damage the plastic or at least fade it. Try to find out what material the panels are made from by locating a stamp on the inside. 99% of plastic products have this stamp.
If the original panels were painted from the factory, then just respray them with vinyl die which can be purchased in spray bombs in the proper factory colour. I've done this tons of times with excellent results.
Give us an idea of what vehicle you're working on as well as colour code if possible.
Dan
Old 06-27-2012, 07:11 PM
DanTwoLakes's Avatar
Wiki Edits: 22
When you say "panels", are you referring to door panels, or hard plastic parts? Mineral Spirits is the solvent for contact adhesive, and won't harm vinyl, leather, Ultraleather, or hard plastic. If these are hard plastic DO NOT USE LACQUER THINNER, it can melt some plastics.
Vinyl dye will not work over paint, you need a completely clean surface to dye vinyl, plastic, leather, etc.
Old 07-01-2012, 09:53 PM
Last journal entry: Century Boat Cushions
Something that works on most plastics is brake fluid. Pour it on and let it soak for a while. It loosens the paint so it can be removed. Just wash the parts good after with soap and water to remove the residue, and prep as usual for your new paint.
Schlock Rod
2 panels painted; one is clear, other milky shad9876 Body - Exterior 14 10-25-2008 12:20 AM
Repair or restore foam filled armrests that have been spray painted ret_marine2003 Interior 3 08-18-2008 12:27 PM
Painted Aluminum Panels KenCam Body - Exterior 2 05-14-2007 11:51 AM
Interior panels? TJ'S30 Interior 30 12-02-2006 10:06 AM
Should I spray paint my door panels?????? Big72Chevy Interior 11 10-31-2004 03:31 PM
