Is this spray pattern correct size for my sata?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2011, 12:55 AM
I have a Sara 2000 hvlp 1.3 and it seems to have a small pattern. I replaced the air distribution ring and still the same. I have a 5hp 20 gallon compressor with 3/8 hose high flow fittings. I was running 3 turns on the fluid and 30psi intel. 6 inch away from the paper. It's a single stage paint.
http://img340.imageshack.us/i/img0710tp.jpg/
Old 01-07-2011, 08:07 AM
http://www.youtube.com/watch?v=NCQ4v5ArByE
Old 01-07-2011, 08:42 AM
Underground's Avatar
Last journal entry: 54
Has it always sprayed this way? Did you buy it new? How big is that pattern? My old Sata jet90 shot a small pattern, and my old Nr95 shot one a little bigger, but my 3000rp shoots one thats about 8-10 in pattern @8 in from the panel.
sata spray gun help angel85lx Body - Exterior 4 01-03-2011 05:00 PM
Need help determining correct spray pressure, please. onpyramid Body - Exterior 2 03-30-2010 06:33 PM
Spray pattern rod kent Body - Exterior 2 09-30-2009 10:03 AM
Narrow spray pattern?? 62galaxiguy Body - Exterior 1 12-21-2005 10:06 AM
FoamFast spray pattern cboy Interior 14 11-14-2005 12:18 AM
