Spray on Texture for Underside of Hood?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2010, 01:50 PM
I am in need of some help here - I am in the process of painting a Triumph Spitfire and the hood looked like a sack of walnuts - all full of dents and little bits of damage. I have hammered and dollied as much of this out as I can but even when the outside of the hood is done, when the hood is lifted on the car, the underside of it will show signs that it has been worked on. I want to spray on some sort of textured finish on the underside to hide the blemishes but I don't know what to use for sure for the caoting. I am worried that the heat from the engine will affect the coating, possibly causing it to melt and drip onto the engine thus creating the possibility of a fire. Is there anything in the way of a heat resistant undercoating or gravel guard that will work and be safe? ANY suggestions will be welcome. Yeah - I know - a Triumph ain't a real car to most roddrs but this is someone's baby and pride and joy. I am just doing the work on it and it's been a ton of labout, let me tell you. So any suggestions??
Old 07-01-2010, 02:57 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Check into a good bed-liner spray they make it several different ways ,
and some of it is fire resistant. http://www.scorpioncoatings.com/ .
Cole
Old 07-01-2010, 03:12 PM
Rix-Trix's Avatar
Last journal entry: Box is back on the truck
You can get a rattle can of bedliner that will give you the texture you are looking for and you don't have to be concerned of it dripping, you would have bigger problems if it got that hot.
Old 07-01-2010, 03:22 PM
TucsonJay's Avatar
Another possibility is "rocker schutz". They used it to texture rocker panels before paint, in the 80s. It has a texture like a rough leather. I haven't used it since the ninties, so I don't know if they make it any more.
Old 07-01-2010, 03:35 PM
Rix-Trix's Avatar
Yes you could use rocker guard or gravel guard but the sprayliner gives more texture and will hide more imperfections.
Old 07-01-2010, 04:57 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You could use a reflective heat barrier, an example is HERE. Some types have a peel and stick adhesive, others use your own fastening system.
Dynamat makes a spray that is nonflammable for under hood use, as well as their hood liner material.
Old 07-01-2010, 06:14 PM
here is a pic of a truck done with bedliner i love it and will do my 68 this way. bed liner gonna use spi
Old 07-01-2010, 07:46 PM
Rix-Trix's Avatar
Looks great, nice texture.
Old 07-01-2010, 08:15 PM
you can also buy a quart of, its called suade, it comes in a form of powder, you just add a little bit to you paint, and spray it on, it comes out like a textured look
Runs Like Crap With Air Cleaner On - why? leejoy Engine 30 11-16-2010 06:08 PM
any help ya'l luvchevs Body - Exterior 6 01-06-2010 09:35 PM
low priced spray gun/detail gun for primer/base/clear and ghost flames jrmy_1 Body - Exterior 15 06-08-2008 06:38 AM
plastic texture spray mitmaks Interior 4 01-30-2005 04:27 PM
welding a metal cowl hood scoop to a metal hood? project66 Body - Exterior 7 11-10-2004 10:25 AM
