sprayable fillers - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2008, 11:47 AM
sprayable fillers
Does anyone have experience and opinions of U-Pol Reface sprayable filler? Slick Sand is an option as well, I've heard good things about how easy the sprayable fillers are to work with. If I could get some feedback I would appreciate it!! Thanks
Old 02-24-2008, 06:05 PM
I have used the slick sand for quite a while with good results. Cant beat the poly primer for blocking and its ability to fill all the low spots without any shrinkage, dont even use the 2K primers any more. Omni MP243 is a good one as well, actually sprays better than the slick sand without adding any acetone. Either one should suit your needs.
Old 02-24-2008, 11:29 PM
Heres some stuff on it.
Sprayable Body Filler
Rob
"There are questions to be answered, and answers to be questioned"
Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything.
http://www.1969supersport.com
Sprayable Body Filler robs ss Body - Exterior 10 11-19-2007 06:56 PM
engine block fillers 65 Impala Racer Engine 12 08-09-2007 02:30 PM
Pro's What fillers do you like? 10Tonhammer Body - Exterior 7 03-16-2007 02:17 PM
Body fillers. what are you using ? pacustomcoatings Body - Exterior 23 11-02-2005 08:35 AM
Fillers Finn Hillbilly Body - Exterior 3 02-07-2005 05:40 PM
