Sprayed clear then wet sanded and buffed and noticed dry spots, parts are not glossy - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2011, 09:30 AM
Ok so after posting an ad about bubbles in my clear coat and getting many helpful responses, thank you all, I've noticed another problem. I'm sure I just overlooked this since I'm a newbie but after i wet sanded with 1500 and then buffed I noticed parts of the car, to be exact on where at, top of the driver side and passenger side door where it curves a bit and then there is the window, I have dryness. The hood, fender, bumpers all came out nice and glossy but this part of the doors did not..
Maybe I didnt lay the clear on thick enough?
Old 07-02-2011, 10:05 AM
It sounds like you buffed through the clear and are now seeing basecoat. When planning to cut and buff, you also need to plan on more clear than otherwise to allow for the loss.
Old 07-02-2011, 10:27 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
where you have curves like that it is easy to buff through the clear..just spot it in and you will be fine..
Sam
Old 07-02-2011, 10:41 AM
yeah either i buffed through it or i didnt put enough on. I put a total of 2 coats which to me looked like enough at the time
Old 07-02-2011, 10:42 AM
its also very orange peel looking where its not glossy, could thid be from poor spraying technique?
Old 07-04-2011, 08:53 AM
deadbodyman's Avatar
Wiki Edits: 11
You should use a rubber squeegy when wet sanding you would have caught that before you buffed...and a soft block so your fingers dont leave groove marks.Sand the dry spots some more and be careful not to sand or buff through the clear.dry spots are usually due to poor lighting..
small scratch lines in buffed clear coat Can57Chev Body - Exterior 5 08-13-2010 05:07 PM
Sanded through clear Benz Kid Body - Exterior 21 06-23-2010 07:11 AM
What is the Most Super Glossy Clear Coat? jeetkunedoground Body - Exterior 29 06-07-2010 10:25 AM
Sanded through the clear. kirkschopped67 Body - Exterior 2 07-23-2009 04:59 PM
I sprayed the clear today, but ? ptcamaro Body - Exterior 5 10-06-2005 10:34 PM
