Spraying Auto Air water borne paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2006, 11:42 AM
HI all,
I am looking at the Auto Air water borne paints. The tech page says 30 to 40 psi. I can only get 25 psi at my Devillbiss Finishline 3 gun. Anyone spray the Auto Air using less air than 30 psi. I have a good compressor and can not get to the 30psi.
Thx, Walt
Old 06-25-2006, 02:09 PM
spraying auto air
I've used it quite abit including the cobra in july Hot Rod for the Quaker State Challenge.
I don't believe the air pressure will be an issue but the air cap size is important and spraying over a uniform base is critical!!!! I painted a fairly big buck pro street car and sanded thru an edge.I didn't think it was any big deal but trust me if you put a dozen coats on that one spot you still could see it.
IT is also important to spray per the tech sheets-----light coats, be patient cause if you load it on -big mess.
Other than that good luck but if you have more questions give them a call ---a good group to deal with.
what else in in wax and grease remover besides mineral spirits? Dubz Body - Exterior 47 06-19-2010 12:09 PM
Paint question for the experts Kevin45 Body - Exterior 34 02-23-2009 05:03 PM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 12:18 PM
Foose Water drop Paint Job rick458 Body - Exterior 18 03-15-2005 01:58 AM
'57 bel air paint mitmaks Body - Exterior 3 12-06-2002 10:23 AM
