Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Spraying big flake?
Old 07-13-2012, 09:49 AM
10Tonhammer 10Tonhammer is offline
Spraying big flake?
What's the best method for spraying big flake (.025). Do you guys like to mix it with intercoat clear and use a 2.2-2.5 tip? Have any of you used a flake buster gun to spray dry flake? I have spray loads of pearls and mettallics but never anything that big. I with have to buy a new gun either way just trying to find out which way is better as the guns cost about the same but with the dry spray technique you don't waste in used flake because you spray it on wet clear instead of suspending it in clear. Thanks
