-   -   Spraying big flake? (http://www.hotrodders.com/forum/spraying-big-flake-221625.html)
10Tonhammer 07-13-2012 08:49 AM
Spraying big flake?
What's the best method for spraying big flake (.025). Do you guys like to mix it with intercoat clear and use a 2.2-2.5 tip? Have any of you used a flake buster gun to spray dry flake? I have spray loads of pearls and mettallics but never anything that big. I with have to buy a new gun either way just trying to find out which way is better as the guns cost about the same but with the dry spray technique you don't waste in used flake because you spray it on wet clear instead of suspending it in clear. Thanks
Kris,
jcclark 07-13-2012 10:56 AM
I like mixing it with intercoat, and useing a siphon
feed gun. It clogs the gravity ones up sometimes.
If I want to use a gravity one I use the DeVilbiss bag
system so I can lay the gun on it's side between coats.
Even turn it upside down and shake it.:pimp:
MARTINSR 07-13-2012 11:30 AM
Depending on how big the item is you are spraying you could simply spray clear and then dumb the stuff on patting it flat and collecting the ones that fall off in a masking tape "catch" under your work and reuse it.
This sounds crazy stupid at first thought (or at least it did to me) but when I asked about applying "bass boat flake" (as I call it) I was told this method and I used it, worked well for me.:thumbup:
I am NOT by any means a custom painter and have only used this giant flake a few times but this method worked and frankly surprised the heck out of me.
