Spraying contact...
From another web site..may be useful for some:
http://www.woodweb.com/knowledge_bas...yApplying.html Sam
sounds like a notched trowel is still the best way to go.
more adhesive less volatile less time to wait till tacky goes where you put it don't have to inhale the adhesive and the volatile |
The link Sam gave you is for woodworking. You do not use the same kind of contact adhesive for upholstery work. You need HHR (high heat resistance) contact adhesive intended for car interior work, or the glue will fail in the summer in a closed up car. Spreading contact adhesive with a notched trowel would take forever and would be a pain in tight areas. You will still have to wait for the adhesive to dry whether you spray it or trowel it. The glue is volatile one way or the other, and if the can is open, you will still have to inhale the fumes. The answer there is a respirator. Why do you have a problem with spraying the contact adhesive, it is the cheapest, fastest, most accurate way to apply the glue?
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
The problem is overspray
the glue must be far more dilute to be pushed thru a hose valve and nozzle it requires a great deal more solvent. then to even think about applying an even coat youve got to be at least a foot away from the spot you aim at. Then after you use it youve got to clean the spray gun and the hose and the can or throw it out. a trowel, brush or knife is far easier to clean you can also do corners edges and small spots with a trowel you can use glue as thick as tar with a trowel Ive seen spray paint used on grafitti, things like railroad cars or retaining walls. labels on drawers generally use a brush. trowells are good for putting glasing (non hardening glue) around windows im sure a spray gun could do the job if you added enough solvent to make it flow through it. next time you put on a gasket, go to your local parts store and ask him for a spray can of gasket cement. |
I don't know what contact adhesive you're talking about, but the object isn't to get a smooth coat like paint. The object is to completely cover both sides of what you're gluing together. The glue has a pebble-like look to it after it is sprayed. I'm talking about Top and Trim contact adhesive, and the last thing you'd do to it is thin it with solvent, 'cuz it will fail if you thin it. You also don't need to clean the spray gun if you use an external mix gun that mixes the glue and the air at the nozzle. The hose doesn't have glue going through it anyway, only air, so that doesn't need to be cleaned either.
I always spray on my work bench which is 31" off the floor, and I haven't had any problems.
spraying contact
I've for the last 28 years always used a cheap spraygun to spray my glue with.Can buy them at harbor freight for about 17.00.I use weldwood adhesive never have had to thin it. Cheap gun most of the time last about 6 months with never cleaning, when it gets stopped up throw it away and get a new one. With the spraygun you can adjust your spray patten so there should not be any overspray.
I agree with the last two posts.
26 years of spraying not one issue. Mask what you don't want glued. With any solvent based liquid you need to Vent area (I put a fan in the door to blow fresh air through when in a car) and suggest using a good respirators. Yep Cheap spray gun, looser cheaper the better. Clog it up throw it out! I brush edges when wrapping or areas that are impossible to spray accurately. |
| Recent Interior posts with photos |
| Need Help Spraying Metallic | rcm800 | Body - Exterior | 7 | 02-28-2007 05:52 PM |
| Ring & Pinion Tooth Contact Pattern GM 10-Bolt | leejoy | Transmission - Rearend | 52 | 12-15-2006 06:26 PM |
| How Does This Stuff Work? | docvette | Electrical | 3 | 06-18-2006 03:00 AM |
| Newbie Spraying Epoxy | Shakey | Body - Exterior | 6 | 06-14-2005 04:23 PM |
