Try this. No idea how to correctly measure the tip size. Why do you want to let it set? I would top coat asap since you don't want to let all the work leading up to now up to chance. http://www.evercoat.com/imgs/pis/FFG2PIS.pdf
Ron,
I have 4 HVLP gravity feed primer guns (Geo's) 1.5 that I use for 2K primers and 1.8, 2.2, 2.5. For the FF/Slick-sand I like the 2.2 the best for a large area but the 1.8 works good for small areas like a side. I have used the 1.5 one time on a master cylinder and it just over atomized to much. This is a porous primer and will suck moisture so should not be exposed outside. All this is , is spray-able bodyfiller. Last edited by BarryK; 09-06-2004 at 06:37 AM. |
