Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Spraying Metallic base *testing gun*
Old 03-17-2012, 10:03 PM
INXS2 INXS2 is offline
I had the same problem with my FLG3 and I had mistakenly left out the fluid tip seal, P/N:690020 (FLG-304-K5), after I had cleaned it then blew it off with my blow gun. It would spray, sputter, then spray. If you look up in the FLG3 parts list it'll be item 4. If it worked before cleaning I'd look there and of course, keep the vent clean unless your using the ventless cups (3m PPS, Devilbis DeKups).
