Spraying Metallic base *testing gun* - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2012, 02:29 PM
67Elcamino's Avatar
Ive been testing my metallic paint with different lower end guns to see which provides a better fan and smoother application. I noticed on my FinishLine 3 when spraying every 10 seconds or so it make a strange sound like air is flapping inside and doesnt shoot paint until the sounds rapidly goes away.
I had this happen to another old gun I had and just threw it away. Ive only used this gun a couple of times but have taken it apart to clean.
For those inquiry minds the other guns are;
Finishline III 1.3 tip
Finex3000 1.3 tip
Purple Harbor freight 1.4 tip
and a cheap Satajet looking no name brand gun 1.4
So far the Purple gun is shooting pretty well.. a $13 gun? can it possible be the 1.4 tip
Old 03-16-2012, 04:24 PM
Old Fool's Avatar
A fluid cap that isnt fully sealing to the gun body is the normal cause of that ailment .
Old 03-17-2012, 10:10 AM
67Elcamino's Avatar
That can pretty much be it. I did notice the cup leaking a bit as I shot. I'll make sure its sealed and give it a shot again. Thank You
Old 03-17-2012, 04:09 PM
Old Fool's Avatar
Cup leaking shouldn't matter other than it is a mess you don't want.
Do make sure the vent hole is open if your cup system uses one.
Old 03-17-2012, 10:03 PM
I had the same problem with my FLG3 and I had mistakenly left out the fluid tip seal, P/N:690020 (FLG-304-K5), after I had cleaned it then blew it off with my blow gun. It would spray, sputter, then spray. If you look up in the FLG3 parts list it'll be item 4. If it worked before cleaning I'd look there and of course, keep the vent clean unless your using the ventless cups (3m PPS, Devilbis DeKups).
Help spraying metallic 69clone Body - Exterior 10 04-27-2011 10:08 PM
metallic base isuses paintech Body - Exterior 3 01-26-2011 05:49 AM
Need Help Spraying Metallic rcm800 Body - Exterior 7 02-28-2007 06:52 PM
Need a good spray gun for spraying metallic base camaro freak Body - Exterior 1 04-18-2006 06:26 AM
Spraying Metallic colors? HOW? novafreek6872 Body - Exterior 7 12-06-2005 11:07 PM
