I think think the prevail sprayers are a good idea for some things but in all the years they have been out I have never used one.
So learned something today and not done with first cup of coffee yet! |
First-hand experience with the Preval!
Hi,
I finally got around to trying out that Preval sprayer yesterday. I mixed up a quart of Endura primer, and set out to prime all of my small chassis parts, i.e front crossmember, control arms, sway bar, motor mounts, etc. I sprayed it all, and used 3 of those little propellant cartridges. I'm quite pleased with the results. The primer has a nice gloss to it and no runs, and not a lot of dry spray or orange peel either! Similar to a good quality rattle-can. Clean-up was a snap! Throw away the propellant cartridge, rinse out the glass jar, and go home! I was able to get into some fairly small enclosed areas on that front cross-member that probably would have been difficult or impossible with a 1-qt siphon gun. It was pretty slow going though. I might use the Preval again when I do the topcoating, to get inside to tight spots ... or to do very small parts with a different color. Otherwise, I think I'd just mix up a quart and use the siphon gun. It's just got to be faster. |
Glad to hear it worked well for you. Might also be handy if you are doing something like an engine compartment or something, and the engine is not removed. You could use one to get into more of a confined space that you can't get at with the touch up gun and hose, but still use activated paint.
| the history of chevy v8's | savman1 | Hotrodders' Lounge | 43 | 03-02-2012 06:57 PM |
| What grit? before and after epoxy sealer ? | 67LS1T56 | Body - Exterior | 7 | 08-17-2005 10:04 PM |
| Small base circle cams??? | Lthompson | Engine | 6 | 04-15-2005 08:00 AM |
| 427ci small block!?! | chevyelc81 | Engine | 13 | 10-17-2002 07:05 PM |
| Small Block 400ci...or...Big Block 396ci???? | chevyelc81 | Engine | 17 | 10-05-2002 07:06 AM |
