spring bushing removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2006, 07:03 PM
i have a new set of rear springs, but they have the wrong bushing in the front eye. what would be the best way to remove them? they are steel encased rubber. i have a few ideas of my own, but i'd like to hear some other opinions. thanks
Old 06-20-2006, 07:21 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Use a hydraulic press
Old 06-22-2006, 03:36 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Depends what you are replacing them with. Some replacement uerthane bushings do not have shells and are designed to either fit into the eye itself or into the old shell.
If yours requires the use of the old shell, just heat the bushing with a torch for a few seconds and push it out like butter.
Welding on a spring bushing bolt? 2-manytoyzs Suspension - Brakes - Steering 7 04-01-2006 08:24 PM
Leaf Spring Bolt Removal Scoops Suspension - Brakes - Steering 8 03-14-2006 08:33 AM
C6 tail shaft bushing removal cboy Transmission - Rearend 11 08-07-2005 05:46 PM
rear upper control arm bushing removal 68chevelle_ss Transmission - Rearend 18 02-06-2005 02:51 AM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
