Spring clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2006, 09:25 AM
MII spring clearance (help)
I'm getting ready to start putting body parts on my truck (48 chevy) and wanted to finish up some suspension work before I did. The springs I got from Yogi's were a little too stiff in my opinion so I swapped them out with 4 cyl. springs. Now to my dilema. When turning the wheels fully to one side or the other, the brake hose from the caliper hits the springs. I think I can machine (read grind) off a little of the tab that centers the banjo bolt and angle the hose towards the rear so this doesn't happen. I'm using a Mustang frontend with chevy calipers. Is there another fix or does this sound okay? Thanks for your help
Barry
Old 08-08-2006, 04:18 PM
Barry
I would not grind on them ... myself ...
I would engineer a wheel stop ... to limit the travel ... GM and Ford do this all the time
Old 08-09-2006, 10:39 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Absolutely agree.
Old 08-09-2006, 11:22 AM
I didn't feel good about grinding on them either but the mechanic that suggested had a point. The caliper (GM) has a slot if you will for the brake line to come through and that is the part that I would be grinding a little. It's nothing more than metal tabs basically. If I were to grind on them it would be no more than 1/4 inch. Still don't know.
Barry
Old 08-10-2006, 08:28 AM
bigjoe's Avatar
Last journal entry: Steering box reversal
Barry
1/4" is a lot to be grinding off of a caliper. I'd try to relocate the mounting tab to move the hose out of the way.
Tip of the day #28 Hood spring installation. MARTINSR Body - Exterior 23 11-16-2012 10:16 AM
Front suspension help, parellel to transverse spring? hoof Suspension - Brakes - Steering 2 04-21-2008 08:36 AM
Any one ever have this spring problem iceman36 Suspension - Brakes - Steering 6 03-03-2006 06:20 PM
Rocker to Spring Clearance AFR Springs DTL504 Engine 2 06-02-2004 12:38 PM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
