Spring height micrometer - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2013, 04:49 PM
ss396si's Avatar
This is my first build,I bought a comp cam 4929 spring height micrometer. I'm reading up on how to measure my stock valves on my 781 heads for my 454.
I plan on installing this k kit for my engine:
http://www.summitracing.com/parts/cca-k11-205-3
My heads are bare expect for factory exhaust rotators,one shim under intake, valves and guides.
I plan on using these locators and shims:
http://www.summitracing.com/parts/cca-4757
http://www.summitracing.com/parts/cca-4779-8
Now my valves are stock, I understand that I install the micrometer over the valve, install the retainer and keepers that are in the k kit. Bring the mike up till valve closes. What do I put under the mike?
Factory rotators or comp cam locators?
On the intake side do I use one shim?
Old 05-30-2013, 05:42 PM
BOBCRMAN@aol.com's Avatar
Use rotator eliminators on the exhaust side. The rotators won't last in high performance use. I usually try to use a .015 shim on bare cast iron, as a wear shim. Most factory heads use the shim when assembled. You will find the spring height is short on these heads. (I JUST READ THE SPECS).That is a mild cam so the rotators will work if you can get the correct spring height. Any kind of high lift cam will require +.050 or +.100 retainers.
The rest is up to you. Shim untill you get the correct spring height. + or -.. Usually you can get within .010 or so.
Old 05-30-2013, 05:46 PM
ss396si's Avatar
where would I find the correct spring height?
Old 05-30-2013, 05:51 PM
Will be with the cam and/or springs. Or cam manufacturers catalog
Old 05-30-2013, 06:00 PM
ss396si's Avatar
Now I'll take a guess and say I'm aiming for seated load(both intake and exhaust valves closed)?
Here is the spring specs:
COMP Cams: Single Outer Valve Springs: 1.524" O.D., 1.110" I.D.
Old 05-30-2013, 06:11 PM
Shoot for 1.900. 122 lbs. That is plenty of pressure for mild hydraulic cam.
Actually I like closer to 110 lbs. Easier on break in and good to 5500 rpm.
Proform Valve Spring Micrometer nofearengineer Garage - Tools 6 08-13-2012 09:37 AM
Spring height vs. Spring rate question oldschool101 Suspension - Brakes - Steering 12 06-28-2011 10:06 PM
Spring Height???? dhunt00c Engine 6 05-10-2008 07:18 PM
Beehive Springs/Valve Spring Micrometer ssmonty Engine 4 10-27-2007 04:41 PM
Spring height?? Bluepen Suspension - Brakes - Steering 2 05-30-2004 07:23 AM
