spring help please! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2010, 11:42 AM
Banned
spring help please!
Where can I find the specs on the springs that came on my 1977 Pinto? I just need to know the ID, OD, spring rate, and unsprung height so I can order custom springs.
Old 05-06-2010, 04:28 PM
spring
go to a auto part store they should have a spring book and should be able to look your car up and give u all the info u need
Old 05-06-2010, 05:09 PM
Wiki Edits: 31
napaonline has lots of specs listed for various things and is a great resource
# Coil Spring Coils : 7.88
Coil Spring Free Height : 13.44"
Coil Spring I.D. : 3.51"
Coil Spring Load Height : 9.5"
Coil Spring Type : One Tangential End; One Square End
Design Load : 1388
Spring Rate : 353
Wire Diameter : .58"
http://www.napaonline.com/Search/Det...+50026+2026028
"Basics of Basics" Hood hinge spring removal and installation. MARTINSR Body - Exterior 21 09-23-2014 08:59 AM
Tip of the day #28 Hood spring installation. MARTINSR Body - Exterior 23 11-16-2012 11:16 AM
What type of cam has the least chance of failing? 4speed57 Engine 24 01-29-2010 04:46 PM
"Basics of Basics" Window regulator spring removal. MARTINSR Body - Exterior 0 11-24-2008 09:24 AM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 09:24 PM
