I saw that happen one time...the guy had the left caliper on the right, and the right on the left.....he swapped sides with the calipers and that put the brake lines in a different position.
Just make sure the bleed valves are pointing up... Don't swap them without verifying orientation...
Mark |
Astroracer is right on on that one.
I'm certain the calipers are on the correct side....bleed valves up and the hoses come in-board. I'm really at a loss on this one unless there is some kind of angled banjo bolt available. There is a notch in the caliper where the hose exits. I could shave a bit off and angle the hose back some but didn't know if that would be a good idea.
Barry |
Is it necessary to turn that sharp?
You could lnstall a stop, so that it doesn't turn that far.
Ontario Rodders |
Is it just the hose hitting the spring? Or the fitting itself?
Poncho...good point and one that I thought of. For any real damage to occur I would have to be turning really hard and also hitting bumps.
Henry...IT's just the hose that hits the spring. I didn't put on braided lines just the rubber. Both sides have the same problem. The line comes out and then I ran it back to pass through the frame but the hose hits a coil just out (or in I guess) from the banjo. |
When this happens on the OEM's they put on a protective sleeve. Cut a chunk of 3/8" fuel line and slip it over the hose in the affected area. Just slit the hose so you can slide it on. Use a drop of super glue to lock it in place. This will be an infrequent occurance so there really isn't anything to worry about but the sleeve will keep you out of trouble.
Is the truck sitting down all the way on it's suspension? Motor and trans installed? Just a question. This would make a difference in ride height. Mark |
All of the above ways will work But. If the caliper has a shoulder around the area where the hose end /banjo block/banjo bolt and it limits the angle that the hose can be installed on, then you can grind some of that shoulder off if it will allow you to position the hose for better clearance. I have done it a bunch of times. Just keep the metal shavings out of the caliper inlet and make sure the banjo bolt is tight after you put it back together..and don't grind on the sealing area . I usually put a short bolt in the inlet hole to seal and protect the surrounding area.. some of the hoses have a small section of tubing between the rubber and the banjo block. If that is the case you could bend the tubing a little. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 09-12-2006 at 12:44 PM. |
im not 100% sure, but i think beenaway2long had this problem with a different vehicle and posted a thread about it on here. A forum search might turn up that thread.....yep it was him, heres the thread : Brake hose/Drop spindles questions 65 chevelle
might be different solution, but its a similar problem... |
I guess no one reads my posts. mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
| Brake line splitter | 3100 Special | Suspension - Brakes - Steering | 6 | 01-08-2006 06:23 PM |
| Disk brake caliper & steering arm hitting | gator412 | Suspension - Brakes - Steering | 3 | 05-28-2005 10:31 PM |
| hole in brake line | 61ChevyTruck | Suspension - Brakes - Steering | 5 | 03-26-2004 01:35 PM |
| Ford spring lock fuel line coupling question | dirtlmfan | Engine | 5 | 07-09-2003 10:52 AM |
| Drum Brake Bar Spring??? | PrimaDude | Suspension - Brakes - Steering | 8 | 02-12-2003 04:16 PM |
