spring holders - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2009, 08:06 PM
spring holders
i just put on new rear leaf shackles on the back of my 49 Chevy 1/2 ton PU
and it made a world difference. I have 3 inch lower blocks but would like it to be about 3 inch lower yet. Has anyone every put the rear spring holders up into the frame. I know I would have to box it out and re-enforce the area but it looks like I could gain about 3" Would this cause and unforeseen problems.
Mark
Old 01-17-2009, 08:16 PM
poncho62's Avatar
Wiki Edits: 5
You would have problems....when the springs compress, there is movement lengthwise along the frame. You need a shackle there to swing back and forth.
Old 01-17-2009, 08:21 PM
I am going to keep the shackles on. Just want to move the shackle holder up further into the frame. It's located on the bottom of the frame now. I would like to cut the bottom frame out and move the holder up to the top plate of the frame.
mark
Old 01-17-2009, 11:13 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
I have done that mod many times. Just make sure leave enough room so the spring doesn't hit the frame. The photo below shows a 35 Ford with the mount just as you describe.
Old 01-19-2009, 05:40 PM
Thanks for the reply and the pic.
Mine is going to be a little more difficult. I going to have to cut into the
c channel and box it and support it. I should be able to gain 3" and I think it's
worth the time.
mark
Old 01-19-2009, 09:09 PM
aosborn's Avatar
Wiki Edits: 7
I don't know if you can tell from the photo, but I cut a side from a piece of 2x3 rectangular tubing and welded it onto the frame to enclose the "C". Then I cut a hole with a hole saw and welded a tube in for the shackle bushing.
Andy
"Basics of Basics" Hood hinge spring removal and installation. MARTINSR Body - Exterior 21 09-23-2014 07:59 AM
Tip of the day #28 Hood spring installation. MARTINSR Body - Exterior 23 11-16-2012 10:16 AM
"Basics of Basics" Window regulator spring removal. MARTINSR Body - Exterior 0 11-24-2008 08:24 AM
Any one ever have this spring problem iceman36 Suspension - Brakes - Steering 6 03-03-2006 06:20 PM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
