Spring Loaded Devices - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2011, 10:46 AM
I want to add spring loaded tensioners under my pick up truck bed and attach a metal rope that I can pull with a counter weight of approximately 10 pounds per tensioner. Ideally, I would like to install these tensioners so that they rotate as I pull them and as they rotate the tension to pull them increases steadily so as to provide a good grip to secure some equipment on top of my truck's bed.
Does anybody have any idea where I can get these tensioners?
Old 04-12-2011, 03:57 PM
poncho62's Avatar
Wiki Edits: 5
Have no idea what you are talking about....please explain better and I will put the question in the proper forum.
Old 04-13-2011, 10:18 AM
el pollo's Avatar
It's shady under this tree...
Why not just use a ratcheting tie-down? They'll likely perform better than a spring loaded tensioner because the springs will hold dead weight, but not a moving or shifting load.
ruff idle, think i need spring loaded needle and seats? spinn Engine 0 06-15-2008 05:12 PM
Car tracking devices Derkyb Hotrodders' Lounge 2 04-11-2007 02:03 AM
Fully Loaded crazygutgut Hotrodders' Lounge 6 07-18-2005 02:36 PM
Loaded Caliper????????? 97Z28 Suspension - Brakes - Steering 5 07-12-2005 04:00 PM
6x2 loaded, is this a good deal? rlackey Engine 3 04-23-2005 04:06 PM
