-   -   spring loaded hose clamps (http://www.hotrodders.com/forum/spring-loaded-hose-clamps-219408.html)
Mach1460 05-15-2012 04:52 AM
Anyone know where to find these? I hate the look of the band/screw style clamps. I've checked auto parts stores in town and Amazon had some but had bad reviews... Google didn't lead me to much..
bracketeer 05-16-2012 05:17 AM
clamps
if your looking for what i think you are. they are dealer part. they have a tendancy to leak if re-used so aftermarket shops dont carry them
Irelands child 05-16-2012 06:52 AM
The last I bought were at the local hardware store in those cardboard bins.
Another way is to use some Gates shrink clamps. NAPA has them under their own name, but here's Speedway's cat
...and on my car:
http://i70.photobucket.com/albums/i8...DSCN1750-1.jpg
LATECH 05-16-2012 05:31 PM
3 Attachment(s)
I think you are reffering to Constant tension clamps.see photo.
They are superior to a gear drive clamp, when sized correctly. Lots available aftermarket.
They get there name because of the way they work. As a hose softens and gets a little deformed, they keep "constant tension" on the hose and will prevent leakage after a replacement hose is installed.
lots of myths surround these clamps, but they are mostly just that, myths.
Ever see one on hose you cant reach, like on the hose under the intake of a 4.6 liter ford moduler engine. If you change that hose, it will be with the intake off, as you cant do it any other way. Point is, if you use a gear drive clamp, after the hose softens and the clamp needs retightened as it will, or it will seep or leak, you cant reach it to tighten. BUT if you use a constant tension clamp, it will keep tension on the hose constant, so .. no leak.
There is a tool for installing them/removing them. Being a flat rate line technician I re use them whenever I can, as with the correct tool, they install so quick your head will spin.There are also many times where you wont be able to turn a gear drive clamp because of its proximity to other parts.
The tool is pictured below also. FWIW
Also last photo bump. :P
against all odds 06-19-2012 08:56 AM
Now that i know why they are used (to keep constant tension as the hose shrinks to fit) ok, fine.
i don't like them because you often need a special tool to install/remove.
i would rather have to check often for leak (i don't) and re-tighten a screw clamp.
