spring perch bolts - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2006, 05:50 PM
spring perch bolts
I am working on a 41 ford front end, trying to take it apart, my question is the spring perch bolt that holds the wishbones on wont come out. I pulled the castelated nuts off, and the bolt wont come out of the axle. Are these pressed in, do i need to use a press to get them off, or should they just pull out.
thanks
Old 06-22-2006, 11:22 PM
willys36@aol.com's Avatar
Wiki Edits: 21
The bolt just slips into the stamped holes in the spring leaves. It is rusted in place. Should be able to hammer on it and knock it loose. A shot of WD40 first will help. Put the spring in a loosely tightened vice or C-clamp first 'cause there is a little stored energy and when the leaves let loose it gets exciting.
Replace the old, shot bolts w/ Allen head cap screws. They are super strong and have the perfect round head to locate the spring in the perch when going back together.
Old 06-23-2006, 07:19 AM
As a Moderator here and a old Ford owner, I would like to WELCOME YOU here ...
I have always had to use a torch ... heat it up to almost glowing red and then use a special tool # 20. ( special tool # 20 is big 20 pound hammer )
Again WELCOME ...
Old 06-23-2006, 08:51 AM
thanks deuce, i have heated the axle up to almost red and used a bfh and wailed on that perch bolt i wont budge, all it did was mushroom the end of the bolt. i even froze the bolt with liquid nitrogen, and heated the axle, but it still wont budge. i guess that 65 years of rust is as good as welding. jk
thanks
Old 06-23-2006, 05:21 PM
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
spring perch bolts
Can you take the band off the leaves? then smack the leaves sideways to break the rust loose. Just a suggestion
spring perch no welding needed ??? Can drive 55 Transmission - Rearend 1 10-07-2005 07:36 PM
spring perch to pinion angle pace69 Transmission - Rearend 1 02-10-2005 08:44 PM
67 camaro spring perch fork Suspension - Brakes - Steering 1 03-24-2004 03:45 PM
'68 firebird spring perch distance firebirdmi Transmission - Rearend 0 02-07-2004 04:05 PM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
