spring perch no welding needed ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2005, 08:57 PM
New Member
A guy today suggested to me that one could make up a perch extention out of flat bar. Bolt it to exesting perch making it match up to whatever distance needed
to match up to spings. And that the ford 150 is very close to his idea.To me it sounds a little lame. But no welding needed
What do you think of this. You would think the after market would be all over this are they ??
( 57-59 Ranchero wagon 9 inch [57".25] into 55 chev 2dr post)
Old 10-07-2005, 07:36 PM
Crosley's Avatar
Wiki Edits: 1659
IF I understand your post.... you are installing a different rear end ( ford) into a 55 chevy car?
The spring perches must be welded to the axle tube. The rear end would try to spin around under torque from the drive train. A diaster would happen
You can purchase pre-built spring perches from several suppilers ie: Jegs , Summit racing, many others.
If you run some type of ladder bar or a four link suspension , then an axle floater kit can be used to mount the rear diff to the springs. Still needs welding
Welding info Kevin45 Body - Exterior 10 08-26-2011 08:09 AM
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 29 06-18-2009 06:54 AM
welder reccomendations? rally4x4racer Garage - Tools 32 10-14-2008 09:00 PM
67 camaro spring perch fork Suspension - Brakes - Steering 1 03-24-2004 03:45 PM
Leaf Spring Pads, are they really needed? OilPatch197 Suspension - Brakes - Steering 1 04-13-2003 09:42 PM
