Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - spring perches
Thread: spring perches
Old 12-12-2003, 09:42 PM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
About the pinion angle.
The angle at the rear end, that is the angle between the driveshaft and the rear end shoul be same as the angle of the driveshaft to the tranny.
About the short rear end. If you are going to use it, I will repaet my earlier advise. Find some reverse offset wheels. They will move your tires out a bit and they look kind of neat too.
