Originally Posted by swompz
Ok, so am I right in assuming you can safely fit.springs with an od. Smaller than the spring pocket?
Yes
In my head the springs need to have something to centralize them.??
I would, as long as the installed height can be maintained (you don't want to use up too much of the available installed height using a stock length valve and a spring cup or locator). But like I said, there are guys who successfully run the springs on just a hardened shim so the spring doesn't eat into the head.
