-   -   Spring Pocket Vs Spring Size vs valve lenth Help Needed (http://www.hotrodders.com/forum/spring-pocket-vs-spring-size-vs-valve-lenth-help-needed-219967.html)
swompz 05-29-2012 05:02 PM
I measured the spring pocket on the bare alloy heads I've perquired & they look to measure 39mm= 1.550"
but im well confused as to what size springs & locator's I can use with them.
do I need to take spring retainer thickness into account when calculating valve lenth? ising an old valve it looks like a 4.911 valve lenth wouldbe right with an installed hight of 1.70"
im only looking to run a .450- .470 lift cam on the motor what options do i have??? :confused: :confused:
cobalt327 05-29-2012 07:05 PM
Different retainers can give different installed heights (see diagram), but the thickness of the retainer doesn't enter into it- the measurement is taken from the underside of the retainer to the valve seat. If you use a spring seat locator, the measurement has to include it, up to the bottom of the retainer.
If you were going to run a high lift cam, a set of +0.100" valves would make sense. But if the lift is below 0.500", no need- just use stock length. BTW, your estimate of 4.911" is right at stock length.
swompz 05-30-2012 12:13 AM
Glad to know I.measured.valve.correctly, but what about.the.diameter of.the.spring pockets? The springs I was going to use.are.only.1.26" od. But the.pockets on heads are 1.550" can I do this & will I need a locator for the springs??
cobalt327 05-30-2012 12:42 AM
You can use a cup (Manley, Crane, etc.) or a locator that registers off the spring ID (shown below):
http://static.summitracing.com/globa...ca-4774-16.jpg
There are those who don't use anything except a hardened shim to keep the spring from fretting against the aluminum head.
swompz 05-30-2012 01:32 AM
Ok, so am I right in assuming you can safely fit.springs with an od. Smaller than the spring pocket? In my head the springs need to have something to centralize them.??
cobalt327 05-30-2012 06:50 AM
Yes
I would, as long as the installed height can be maintained (you don't want to use up too much of the available installed height using a stock length valve and a spring cup or locator). But like I said, there are guys who successfully run the springs on just a hardened shim so the spring doesn't eat into the head.
engineczar 05-30-2012 07:14 AM
You definitely need at a minimum a hardened shim to protect the aluminum head. I've used both the cup type and the I.D. locator type. Both work fine. In either case you need to verify the guide diameter to make sure it drops into place ok. As Cobalt said you also need to account for the thickness of the cup which in most cases is .06
swompz 05-30-2012 08:14 AM
thanks for the input guys.
So to summarize "correct when wrong"
It is safe to use a valve spring with the od of 1.26"
http://www.summitracing.com/parts/SUM-174001/
on a alloy cylinder head that has a spring pocket diameter of say 1.54"
However At the least I will need hardened shims to stop gailing of the head, or preferably spring locators or cups.
Installed spring height obviously needs checking.
I cant help but feel that there should be something stopping the bottom of the spring from moving.... A spring locator will obviously do this, however I cant find any listing on summits site of a shouldered locator that has the correct od for pocket & spring fitment.
any ideas lads?
Thanks
again.
cobalt327 05-30-2012 08:44 AM
It is safe to use a valve spring with the od of 1.26" on a alloy cylinder head that has a spring pocket diameter of say 1.54"
any ideas lads?
Thanks
again.
I've never tried to use a stock diameter spring on a 1.54" spring seat, but if I were going to do this, I'd look for a locator like I pictured above that locates off the spring ID.
cobalt327 05-30-2012 08:49 AM
You need to know the ID of your springs. Here are a couple internal locators for 0.570" and 0.505" spring ID.
swompz 05-30-2012 08:51 AM
Seems like best idea to me two , but cant find anything.
Likewise Im having trouble finding a valve spring set/ caps collets etc the right size for the spring pockets with an open pressure no more than 350lb
:sweat:
springs I was looking at have following specs
Number of Springs Per Valve Single
Outside Diameter of Outer Spring (in) 1.260 in.
Damper Spring Included Yes
Spring Rate (lbs/in) 357 lbs./in.
Inside Diameter of Outer Spring (in) 0.875 in.
Valve Spring Style Standard
Coated No
Retainers Included Yes
Retainer Material Steel
Locks Included Yes
Lock Style 7 degree
Lock Groove Quantity 1-groove
Lock Material Steel
cobalt327 05-30-2012 08:52 AM
:sweat:
See post #10.
swompz 05-30-2012 09:07 AM
See post #10.
So would they locate on the valve guide oposed to the edge of spring seat?
if that was the case with valve spring cups , Im in business.
http://www.summitracing.com/parts/MA...6-16/?rtype=10
cobalt327 05-30-2012 09:27 AM
Those will work if the guide boss OD is around 0.525". Obviously, if the guide boss is larger, the cup ID can be enlarged by hand.
swompz 05-30-2012 09:41 AM
Theres no guide boss as such the heads have bronze valves fitted directly into the head face.
