spring pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2004, 08:59 AM
cadallac's Avatar
New Member
spring pressure
i need to know why you have to have so high a pressure on the springs of a roller cam it dosen't make any sence and i talked to a lot of racers but no one knows the answer only that yo have to
Old 01-27-2004, 09:14 AM
camaroman7d's Avatar
The ramps are so steep (how fast they get to maximum lift), this is their advantage. This requires higher spring pressures to control the lifter (so it doesn't jump off the cam). If you do not run high enough spring pressure it is damaging to the lifters, valves, valve seats.
Royce
Old 01-27-2004, 09:24 AM
johnsongrass1's Avatar
Race it, Don't rice it!
As well as controlling valve loft or float. Rollers wiegh in at a Ounces rather than Grams for a flat tappet hyd.
Old 01-27-2004, 10:40 AM
King of my Man-cave.
To put the last two post together, the heaveier lifter is moving at increased velocities so the loads are heavier, hence the need for increased spring pressures to control valve bounce and lobe launching.
Old 01-27-2004, 01:10 PM
cadallac's Avatar
New Member
spring pressure
thanks fellows i can understand that now what is the lowest spring pressure for the roller cam
Old 01-27-2004, 01:18 PM
Depends on the Intended RPM but for stock applications no less then 300 pounds over the nose.
Old 01-27-2004, 01:41 PM
cadallac's Avatar
New Member
spring pressure
time to tell you what i have. 71 chevy nova 355.>steel crank 12/1
pistons forged>555/578 crane cam> solid lifters>balanced', 462 heads ported and polished,202 intakes 160 exaust>holly dominator intake >holly 750 dp carb >all the goodys to go /with it powerglide trans brake 513 rear full spool 11 inch rinkel slicks and i want to go to a good roller it turns 710 in the 8th now got any sugestions??:
also it has a 5500 stall convertor
Old 01-27-2004, 03:04 PM
Call your prefered cam company and give them the same details you just listed and they will set you up with a cam and springs.
Royce
Old 01-27-2004, 03:18 PM
brainsboy's Avatar
brains
You have to goto crane cams website, it will tell you what spring pressure to use.
Its hard to know what spring pressure a roller cams need because you cant go just by duration,lift,rpm.. You need to know technical things such as ramp speeds, ect,ect, things that you probably dont have the specs on. This is why a crane cam and competition cam although may have the exact same duration and lift listed but will be two totaly different cams. Comparing cams is very difficult with only the information they give to the consumer.
Old 01-27-2004, 03:23 PM
Lobe profiles differ but you woul be safe with 220# on the seat and 550# open. You will need to change dist. gears to a bronze gear.
Chris
