Personally I think I would go for about 300 or 350 in the front..the 125/150 in the rear is fine..you may wish for some aux airbags in order to stiffen things up a bit if you need to..this suspension stuff has lots of compromises to it in order to get a decent ride and it sthandling..Myself I like them a bit stiffer than some to get the cornering that I like..
You might wish to use the field expediant method and just remove some leaves from the stock springs and give it a test hop or two..if all the bolts are clean and well lubed changing a leaf spring is not all that hard.
Sam
