Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Spring Question for Mr. Billy Shopes
  #19 (permalink)
Old 07-02-2010, 12:13 PM
BillyShope's Avatar
BillyShope BillyShope is offline
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
Originally Posted by OLNOLAN
...for example on a 2000# front end, 1000# corner load would equate to a 26#-230# spring rate. The rear weight of 1365#/682# corner load would equate to a 18#-157# spring rate.
One more time: This is wheel rate, not spring rate.
You're talking a range which spans almost an order of magnitude. This is meaningless. If you want a vehicle which rides like a luxury car, you can't start with a beam front axle. The compromises I described resulted in the introduction of independent front and rear suspensions.
http://www.racetec.cc/shope
