Originally Posted by Minor Problem
Thanks guys...The only reason I was asking was,I'm building a prostreet Morris Minor with a "stock"narrowed MII frontend and with the 350/350 combo in it, the lower a-arms are still not level and was looking for some sort of a starting point.It's about 1 1/2" to 2" from level.I'm thinking about cutting 1/2 a coil off and trying that.Cutting too much and I'm going to have a shock travel problem,not much there!If that doesn't work I may go to coilovers. Thanks again...Frank
Cutting half a coil id a good way to lower the front about 1 1/2" to 2" (remember the drop in the spring height is magnified X2 out at the wheel). You can cut the spring w/ abrasive disk or just torch it off. I know the problems w/ heating heat treated steel but this is at an extreme end of th wire that snuggles in a groove in the A-arm at very low stress so no harm is done cutting it this way. Half a coil Doesn't affect ride quality perceptibly. My theory is try cutting a coil on a stock spring and see what happens. If it works you saved an iron tree (not to mention precious $$$$$$$), if not no big loss, just buy the after-market spring you would have needed in the first place.
